D Djbhawaii New member Joined Nov 16, 2025 Messages 1 Points 1 Nov 16, 2025 #1 When fuel is used air is not getting back into the tank causing it collapse. Any idea what could be wrong?
S Spike Member Joined Oct 4, 2025 Messages 33 Points 8 Nov 20, 2025 #2 Your vent is plugged. It is at the rear of the drivers door opening. You have to take off the plastic cover that goes around the door catch. I would put a metal roll over valve in place of the factory check valve while you are in there
M Misterb New member Joined Nov 4, 2025 Messages 5 Points 1 Nov 28, 2025 #3 Check with your dealer. They replaced the vent valve in my XR.
