Kawasaki 2024 Ridge newThe rpm's
Dan
The rpm's are running too fast on the road . It has factory tires 14 x 30's. Would new tires 14x32 help the noise any?
I am in the process of buying a clutch kit for my XR , any thoughts on which kit to buy. My objective is to get a little smother entry and reduce RPM
I put in the Cornell Customs primary spring and spacers. <$100 and worked pretty well. Much smoother takeoff and less rpm.
I put a clutch kit in my XR from aftermarket assassins. Set it up for road. Brought the rpm way down and made more low end power. I'm doing the same thing to my XR crew
Thanks good info . Did you put the the overdrive cover on as well or just the spring and weight kit ?
Latest Posts
