Raising the floor board 2.5"
dwillauto
For shorter passengers or drivers: I was able to raise the floor 2.5" with a 24"x60" raised platform purchased from "websturantstore" . I made a "pic stick" which I called a pattern stick in the video and then was able to create a pattern which i could mark every corner and edge and then cut out the pattern with a saw. I only has to grind a little on the bottom where the floor sides are tapered. I used both ends of the platform so I would have a factory edge showing with the door open. Worked great and also I found a container that fits perfect under the passenger seat that hold tow strap, jump box, plug kit, bunges etc... Check out the video. For anyone near Little Rock I can mark you platform for you with the pattern I already have.
