Kawasaki ridge xr winch install
That looks great! It's not as cramped as I imagined it to be.
Looks great! Just bought an XR and would like to do the same. Would you happen to have a parts list of everything needed? Did you use a rocker switch in one of the knockouts in the cab? Thx!
Hey guys just got done installing the Super ATV Black Ops 6000 lb winch and KFI winch mount kit everything lined up great no interference went very smooth! Definitely recommend both products let me know if you guys want to see pictures video or anything of the sort
Where did you mount the relay that came with the winch
Pop the front hood off... there is a space on the driverside under it. Then the positive and negative sources are passenger wheel well behind headlight area and next to radiator I'll try to upload a in-depth review and post here
will you send pics of where you ran the wires down and where you hooked up the small 12 volt wire
Hey, looks great! I would love to do this as well to my XR. I was just concerned because when I look at the KFI mount, the page says that on an XR the WN6000 will not fit?
Also, did you have to make any modifications to the plate for proper fitment? Thanks for the info!
