- Joined
- Nov 29, 2023
- Messages
- 47
- Points
- 18
Kawasaki RIDGE® Key Features
- Kawasaki-Built 999cc Liquid-Cooled, 4-Stroke In-Line Four Cylinder Engine
- Roomy Interior with Premium Comfort
- Full Cab with HVAC (HVAC & Limited models)
- Long-Travel Double Wishbone Suspension and High Ground Clearance
- 27-Inch Tires with 14-Inch Aluminum Wheels
- All-LED Exterior Lighting
- Continuously Variable Transmission (CVT)
- Power Mode Selection
- On the Fly Electrically Selectable 4WD & Rear Differential Lock
- Chassis Designed for Comfort
- 1000-lbs Capacity Tilting Cargo Bed
- 7-inch Full-color TFT Instrumentation
- 8-inch Garmin Tread (Limited model)
- Adjustable driver seat
- Automotive-Inspired Fit & Finish Exterior and Interior
- Smartphone Connectivity via RIDEOLOGY THE APP POWERSPORTS
- Kawasaki STRONG Three-Year Limited Warranty
Ignite your off-road adventure with the turn of the automotive-style key, as the all-new RIDGE® XR side x side from Kawasaki roars to life with its distinctive tone and 999cc liquid-cooled, 4-stroke in-line four-cylinder engine. Setting itself apart from the crowd of twin-cylinder-powered sport-utility side x sides, the RIDGE XR promises an exhilarating experience. Feel the smooth, linear throttle response as you navigate corners, enjoying precise control and a surge of acceleration directly linked to your right foot. Crafted for comfort, the RIDGE XR boasts a wide-track chassis, long-travel suspension, and high ground clearance to confidently navigate obstacles while maintaining cabin tranquility. The in-line four-cylinder engine's low vibration adds to the premium ride comfort, creating an immersive driving experience.
- Full Cab with HVAC (HVAC model)
- 30-inch Tires with 14-inch Aluminum Wheels
- All-LED Exterior Lighting including Accent Lights
- On the Fly Electrically Selectable 4WD & Front-Rear Differential Lock
- 1000-lbs Capacity Tilting Cargo Bed with Detachable Tailgate
- Automotive Inspired Fit & Finish Exterior and Interior
