Old Sailor
- Joined
- Apr 26, 2025
- Messages
- 8
- Points
- 3
Heater is warm but not enough. I think engine running to cold right now but will be worse the colder it gets. I was going to try blocking off some air flow through the radiator with some cardboard. Didn't know if anybody else noticed this. I did this on my rangers & worked fine. I blocked off 1/2 the radiator flow so it would warm up better. Just don't forget to remove it when warmer outside. These crew cabs require more heat & the engine is quite a bit farther back from the heater core & radiator. Basically, the cab heater takes all the heat the engine can produce.
