Thank You, look over all and seems to be good. Thanks for responding, thinking of aftermarket clutch maybe that’ll fix problem. Also hopefully fix the belt squeaking when first starting to move, this happens Every time start to move. Thanks AgainHave you replaced the fuel filter? Check the tank vent? Either could starve it of fuel. If it is fine when cold and gets worse as you go it could be a plugged up tank vent. Try taking the gas cap off when it acts up. See if there is pressure or a vacuum on the tank. See if it is better after you put the cap back on for a bit.
