Just wondering if everyone is happy with their AC. Used mine the other day and it wasn't quite as cold as I thought it should be. 84 degrees and ok inside but not as cold as I thought it should be. I would think you guys down south hitting 90 and above would notice this more than me. I did notice that if I stop with it running it is definitely better inside the cab. The faster I go the warmer the cab gets, yes there is alot of heat blowing in at speed especially between the seats at the back of the console. Maybe it is as simple as taking out the console and insulating it and trying to plug that big hole at the bottom at the back of the console. I believe after another drive the AC is Probably cold enough it is the Heat generated inside the cab, that console produces a ton of heat Any thoughts on the heat from the inside??
