Roadrunner Arizona55
- Joined
- Jul 18, 2026
- Messages
- 13
- Points
- 3
I have air leaks coming on the cab inside on the doors due to not being sealed up properly as received. The doors are two paneled on the outside and where they are joined together horizontally inside door panel running the entire length of the door (see attached pictures) As the fall temperature's have gotten cooler it is very noticeable. For now I have taken a long strip of painters tape and covered the area in question inside the cab. I have made Kawasaki aware of the issue and they should take care of it. It would be a very easy fix at the factory assembly. For a $40.000 dollar machine they certainly could do a better job before sending them out. Its very drafty.
