Door seals
steved57
So I have a new Platinum Ranch Edition and today it was parked outside the garage and we had a strong storm cell blow thru and it rained hard / sideways for 20 - 30 minutes and when I opened the doir I found a pretty good bit of water had gotten in on both sides
I know it shouldn't be but Is this the norm ?
You could buy the OEM door rubber seals that come down from the top of your door halfway down. Buy one set then you cut it in half and it will do both of the door bottoms. Completely around and you’ll have a little extra if you have a four-door you’ll probably have to buy two of them, but helps a lot.
I found it amazing that the lower part of my XR Limited front doors did not have seals. I had them installed and have gone through water up to the underside of the doors with no leaks.
Good morning ☕🇺🇲. I recently purchased a Brand New 2025 Ridge Limited and the Driver's side door has a Terrible Gap when you close it you can see a lot of daylight at the top and corner going down towards the front of the cab and window.
It's currently in the shop where I purchased it I hope to get it back today and see how they fixed it.
