B Prichard
- Joined
- May 11, 2025
- Messages
- 1
- Points
- 1
Has anybody had an issue with the drivers door popping to the second latch when driving. I’ve tried adjusting the striker plate but it still does it?
Do you have an pictures of the fix?I finally took the door apart in my shop, since the good folks at Kawasaki in Billings didn't get the job done, and after some poking around, it seemed to me that the outside door latch spring is just not strong enough to handle the bumps of off-roading. I had a spring laying around that was about 4" long with a loop on both ends and of medium strength, so I opened one loop and placed it over the round shaft of the door latch and zip tied the other end to a part of the frame right above the latch assembly. This adds enough tension to the latch that it never popped the door even on the potholes on our rough gravel road that always popped it before. I hope this rather simple fix works for the rest of you ........
Did you have an issue with the door of your vehicle popping open and and have you performed the procedure you described?The actual problem is the link from the outside door latch to the catch mechanism. Grinding isn't necessary and isn't a good idea.
If you remove the latch and take off the bent link that goes from the outside door handle part you can streighten it a little bit until the link on the latch side is touching the latch body. It will stay latched. Nobody will be able to tell you did anything to it.
I did. Usually it would just pop half unlatched. Enough to rattle. Once in a while it would pop all the way open but that could have been the door not being shut all the way.Did you have an issue with the door of your vehicle popping open and and have you performed the procedure you described?
